FINALLY got the brakes done (after 8 years of ownership and almost 50K miles!), along with a full flush of the brake system and clutch system.
Whoosh 'J hook' slot rotors front and rear, along with Motorcraft factory 'S' pads, and all new hardware (retainer clips, boots, slider pins, mounting bolts).
Goodridge stainless braided brake lines (bought from Ron at Whoosh), and Bosch DOT4 LV brake fluid (highest wet and dry boiling points available in any DOT 4 LV type fluid on the market).
Big thanks to Otis @Next Level Auto in Plainfield, N.J. for the great labor at less than a third of what a dealer would charge for the same, IF you could even find one (or even a private shop) willing to use your supplied parts.
He even wire wheels the rust/crud off of the hub faces/lugs in order to avoid any run out problems, just like in the Royal Auto brake video on you tube.
I am pretty sure that the dealers do NOT do that extra step, and if requested, they would tack on another $150.00 to the bill for the extra 20 minutes work.
I will post up pics when the camera fully charges.
