Almost 200,000 miles now this? Code U012D
chapmansboro
It's been a while since I visited as life has taken over, 2017 ST, 198,000 miles, my daily driver for 6 years and I drive 50 miles each way to work 6 days a week. Whoosh stage 2 tune for 5 years and no problems, replaced the alternator about 2 years ago and yesterday I got this code U012D, battery light on and Accessport says it's an lost communication with generator control module? It Idles fine but as soon as I move the entire dash go's dead, no head light's, no electric assist steering. and no gas pedal? HELP!!!!! Has anyone had this issue and solved it? COOP
T
chapmansboro
I put a new battery in it Sunday afternoon, idles just fine and charging between 13.5volts - 14 volts depending on the voltage needs but as soon as I drive the car even it the driveway I loose all dash and radio, lights and everything electrical?
Did you do a battery reset procedure after replacement?
HB, CA
Is that this -
---> Turn the ignition on, but don't start the engine
---> Turn the headlights on
---> Pull the high beam stalk five times in a row (not by blipping it - you must fully engage it making sure the blue high beam indicator is turning on and off)
---> Depress the brake pedal three times in a row
---> Finally, watch the battery indicator blink three times indicating that the BMS successfully has been reset.
T
chapmansboro
Is that this -
I did reset all codes with my Accessport but I'll try this and see if it helps, thanks. COOP
