My '15 is going on 109k miles and for the first time I'm experiencing clutch pedal problems. Twice now, the pedal has gotten stuck halfway up and was easily released with my foot. There's also a clear detent in the clutch travel now.
There was no fluid leakage at the clutch pedal or master cylinder. I got the car up on ramps to inspect the lines, the underside of the brake master cylinder, and to bleed the clutch when I noticed that the clutch bleeder nipple and rubber cover was wet with brake fluid. There was no sign of brake fluid dripping down from the bleeder or any of the lines. The clutch has never been bled or replaced. I'm assuming this isn't normal right? I ended up not bleeding the clutch, just in case I have to find a replacement bleeder first.
