Vibration.
rallytaff
Los Angeles
I just noticed vibration through the steering wheel when doing about 60mph on the freeway. Had the wheels balanced, no problem. Checked the alignment, no problem. Brand new Lionhart tyres on the front about a month ago. Took it to the dealer and a mechanic checked underneath and noticed some slight movement in the stabilizer bars. Will replace as they're only about $30 each. Is he correct in his assessment? Just curious.
Atlanta
Brake rotors been really hot recently?
More than once, runout on the rotor has been the source of irritant vibrations for me.
R
rallytaff
Los Angeles
Brakes have never been abused. Haven't done a canyon run in years!
Zormecteon
Kelso
Did it only start when you got new tires? .. Do you have aftermarket rims? If the latter are the concentric rings still there? .. Never heard of LionHeart tires. Cheap Chinese from a bit of research....
Go get a set of decent tires. Not the place to cheap out on a performance car.
I believe that Braids are hub-centric, given that every one is basically a custom build to order for the application.
But I agree with you on the tires thing, especially given those great wheels. [wink]
R
rallytaff
Los Angeles
It's NOT the tyres. This is my 3rd set with no problems. Maybe cheap but I'm more than happy with their performance. No rings on the BRAID rims. Not needed. I've had them for nearly 6yrs with no problems, so I can take them off my list. I'm going to go out tomorrow with the traction control off and see what happens. If it persists, it's going to the dealer for new stabilizer bars.
As an aside, car flew through the smog check today. 10yrs old and still good!
Suwanee
rotate the tires front to back. if the vibration goes away or stops coming through the steering wheel, you got a bad tire. it happens.
R
rallytaff
Los Angeles
I'd thought about that. I also bought two new tyres just in case I'd flat spotted them doing an emergency stop on the fwy. I might just throw them away and fit the new ones. Here, they're $80 each. I ordered 2 from W. Virginia, paid $53 each with free shipping. Arrived 2 days after ordering. We get ripped off here.
R
rallytaff
Los Angeles
Had the sway bar links installed today. Will take the fwy tomorrow and see if the problem is cured. If not, I'll get the new tyres installed.
I Think that the tires need to be road force balanced or a wheel may be bent* Keep us up to date....[driving]
It takes A LOT to bend, crack, or to cause a Braid wheel to go out of round/true.
They are one of the strongest brand wheels on the market, including many forged brands which co$t (even) much more coin.
R
rallytaff
Los Angeles
I was just going to mention the same thing, but you beat me to it. It's the strength of the wheel is why I bought them.
R
rallytaff
Los Angeles
Vibration is much less than previously. Will check again tomorrow and may put on the new tyres if it still annoys me.
R
rallytaff
Los Angeles
Still getting vibration so the new tyres are going on tomorrow!
