i just got the whoosh turbo inlet elbow, whoosh crossover, then the maperformance intake. nothing really seems like they were meant to fit together with this setup. the silicone going from the elbow to the crossover has a weird gap on one side when tight and the elbow seems like it might not be at the correct angle causing the crossover to sit at a weird angle making it touch the soft insulation on the motor. also there's the issue of the crossover to intake silicone being the same diameter as the crossover taking an hour to get on. So finally because those 2 dont seem to fit right the map intake angles to far to one side and is only just able to bolt into where it should.
im looking for suggestions on how to fix the fit of everything in general.
ive also learned that the silicone whoosh supplies going from the crossover to the intake is to small in diameter which is why it took forever to finally get on so if anyone would know what size/ angle to get that would be cool aswell so when i do have to take everything back out it wont be another nightmare.
