I'm likely ordering some inexpensive custom wheels that I stumbled onto last night. Every aspect is customizable. At this point, I'm having a hard time making choices. I'm conflicted by too much internet research. For both of the following wheel choices, I'd go with 215/45r16 Falken RT615k+:
- If I go for aesthetics, what's the perfect flush, no poke, no-rub offset? At 40, do folks who are running Dekagrams notice any negative handling changes? Those seem to be just about perfect to me. Konig's seemingly never going to produce bronze and I don't want black on my black car.
- If I go for handling, at 16x8 can I go with the stock offset to avoid scrub radius issues, or would the tires rub suspension bits?
I read just about every obvious pinned thread and used search, but I didn't find any posts rendering a clear judgement on either point.
Valid questions that I have had as well. From the responses I got (on the dekagram thread), it seems that performance handling is not compromised from the reduced offset.
Going from 47.5 to 40 is not really a big difference. I'm running 42 offset on my winter tires and do not feel any weirdness. There might be slightly more torque steer, but honestly I cannot really compare because the tires are completely different than the stock tires.
Another point, the dekas being 8" wide should negate any loss of turn-in performance lost going from 17" to 16". I say "should" because I have not mounted my new dekagrams (sitting in my living room awaiting the "thaw"), and have no personal experience to speak of.
*A lot of this also depends on the tires you run, of course. I'm planning on bfg sc2 205/45, btw.
On your other question: I would think you can go up to at least 45 offset with an 8" wide wheel , considering the Avanti storm run that offset in a 17 x 8.
