UPDATE: Just found a video, might cover most of what I need other than torque specs, hope no more tools needed, I have the cam locking tools already.
While swapping to a 2014 low mileage engine I make a serious error which is quite rare for me and quite embarrassing as well. I did not know the crank pulley was not keyed, another bright idea that one, and when I had the bolt loosened up decided to swap the flywheel over from the 2014 engine, when tightening up the flywheel bolts it turned the crank and caused at lest two bent valves as two cylinders are now low on compression. I was so pissed at Ford and myself I let the car sit since around 2021....time to pull the head and fix it and find a new home for a very quick and highly modded 21,000 mile ST.
I had the manual downloaded back in 2014 but cannot find it on my system, any idea where to get it without spending a lot for it, better yet free, please let me know.
Thanks,
Rick
Thanks,
Rick
