Hey all,
Just looking for a 2nd/3rd/4th/etc. opinion.
Halfway through my second session at the track this past Monday I started having issues getting any gears when shifting at higher RPMs (>3500).
No grinding or any adverse noise coming from the transmission just refuses to grab another gear (up shift and down shift).
Transmission is a pumaspeed rebuild unit with a quaife LSD, RTS twin friction clutch/flywheel and new slave cylinder about 11K miles ago (for all transmission and clutch parts).
At the track I tried adjusting linkages, re-bleeding the clutch, changing the trans fluid (fluid that cam out looked pretty good, only about 1200 miles on it).
My assumption is slave cylinder or clutch/pressure plate issue, I swapped the clutch master and bled it again yesterday, no dice.
Anyone have any other things to check before I yank the transmission out?
Thanks.
Thanks.
