Hey guys,
I found this thread on a mini forum and wanted to share it with you all. As I think it’s important to our platform as well. The post involves a mini copper a with a 1.6 turbocharged direct injection engine. And he did a Dyno test before and after a walnut blasting. And the results are amazing. He gained as much as 35 horsepower and 30 ish torque just by cleaning his intake valves. This was done with a stock vehicle and I believe I read on the original post that he was somewhere around 100k miles for this test. So there was a decent amount of build up on the valves. I have copy and pasted the post from the mini cooper forum below for your viewing pleasure. It includes pictures of the valves along with the Dyno sheet.
Wanted to share this walnut blasting cleaning with you guys. I'ts my dads car, recently bought. '08 Mini clubman john cooper works 211hp. 1.6 direct injected turbocharged engine.
When i drove it i felt like it was holding back, hesitating and not delivering power.
I have put the car on our superflow 4x4 dyno and measured. Then cleaned the valves using our walnut blasting tool and after that used the tunap valve clean spray with running engine.
Let these results speak for themselves
Black lines stock before valve cleaning. Red lines after cleaning
Stock with dirty valves 191 hp
Stock with cleaned valves 211 hp ( exactly as per manufacterer! )
Testdrive after cleaning also confirmed a drive without hesitation and improved performance.
