Hey guys, quick fyi. I have these wheels in 17x8 with 215/40/17 yokohama neova AD08R's. I'm on mountune springs and rub slightly on compression on the plastic wheel liners right where it sits next to the fender lip. Rubbing occurs more on compression when going over dips at speed than in turns. Currently around 1.2 deg neg camber and I'm not really sure squeezing more camber is really going to clear the tires of the liner. I may try it or just trim the liner back. Also the yoko's have a much more squared shoulder than the stock tires in addition to being much wider so that doesn't help.
If you get these wheels I'd suggest running slightly narrower 215's or more camber (coilovers w/ adj plates would help here). Anyways, the issue is very slight but I thought ppl would like to know.
