No, and yes.
The centering pieces won't fit inside the pierce bolting cups. What you'll have to do is make some spacer to get the chambered center, which normaly is used for the bolt big washer, flush to the outer edge. Then the pierce bolting cups will sit flat on those spacers/edge. If you try to bolt the bar without some spacers, you won't have a good strong mating surface between the centering kit and the bar cups.
