Came across a Kona Blue FiST about a month ago and was able to buy it. It's been ridiculously fun, I'm absolutely loving it. However, it started throwing two evap codes and a purge valve code about a week ago. I went and removed the evap hoses and the purge valve and found that the purge valve had been previously replaced, but the evap lines were cracked at the purge valve ends. The fix that they came up with was putting some thin heat shrink on the cracked bits, which evidently worked for a time, but it wore through and isn't working anymore. I tried a more permanent fix with some vinyl tube and hose clamps, but that didn't seem to work either. Still showing codes and there's a funky noise up front that I can only assume is a leak from the lines. Can't find the OEM evap lines anywhere online, either out of stock or just not there. Does anyone have anything they've done that worked when replacing the lines or any other suggestions? I'm hoping to figure something out without having to break the bank. I have another vehicle so I have some time, but I was hoping to post it for sale and can't really do that until I fix the FiST. Thanks.
TLDR: Purge valve lines cracked at purge valve end, need a permanent and ideally economical fix.
