- Member ID
- #16100
- Messages
- 45
- Likes
- 19
.....The discussion only refers to ride height. The question is does ride height change if you use the same spring on two different dampers? B6 vs B8. I claim that B8 damper with the stock spring will have a higher ride height than the B6 damper with the same spring. You claim that it won't?
.....All other things being equal (damping, gas pressure, lower spring seat location), I'm claiming that just changing the "starting" shock shaft length by an inch will not change the ride height once the damper compressed to the operating range of its stroke.
If there *is* a difference in height between the two, there has to be some other difference between B6/B8 besides the shock shaft, or else some manufacturing variation between the dampers you have, like maybe lower gas pressure.
I'm taking a stock non-ST car with stock oil shocks and putting on ever-so-slightly lower stock ST springs on with B6 dampers, and hoping the gas pressure will keep me pretty close to my stock height S car. I don't really care about lowering it. Hoping the spring rate on the ST springs is slightly higher than the S too....
