I been having a misfire for months now, first started with the car getting CEL not long after reaching full operating temperature and with that came limp mode also for the very first time in my life.. since then I have replaced:
Coil packs
Spark plugs
Boost sensor
MAP sensor
MAF sensor (removed high flow panel air filter and installed new genuine air filter at the same time)
High pressure fuel pump cam bucket
Where that got rid of all the codes but the misfire only at idle has gotten worse and more often and randomly goes into limp mode with CEL ect, also hearing a tick or a click sound when each misfire occurs.. mostly happens when engine has been at operating temperature for a while but I also get the 3 cylinder hot or cold startups.. can smell unburnt fuel at startup most times and takes a couple of extra cranks than normal to start..
Next thing to replace I think will be the EVAP vacuum tubing and purge valve ect as I heard (from an American) that they can go at as low as 30 - 60 thousand miles.. I have just recently hit 139000km...
Car never has a problem when accelerating hard just at idle and light throttle input..
Coil packs
Spark plugs
Boost sensor
MAP sensor
