Unfortunately this is not a bolt on solution, might fit up front but you may have to roll the fenders a bit though you can loosen them up and move them out maybe just far enough.
Also the wheels come very close to my BC struts, I had to add the camber on the top by drilling new holes for the tops. If you get camber plates that might do the trick.
On the rear, major issue, you will have to add camber which I feel the car needs anyway, or major fender work. I cut and changed the camber and toe, it took four tries, serious amount of time, etc...to get it right, then I found out the none ST rear beam setup already has -1.5 camber but read below.....
The ST knuckles are machined at an angle, there may be a combo of none ST, if they fit, knuckles and rear beam axle needed for a bolt on solution but also it might be the knuckles only are needed on the ST beam. IF you go none ST beam then is is softer and you then may need to work out a sway bar solution.
The other option is to get shims machined but I could not find a place to make them unless I had tens sets made and nobody seemed to want them besides me.
I would look into the none ST knuckle, they are cheap but you can get one from a local yard most likely just so you can compare and see if it adds more camber and what it does to the toe setting, I wish I had thought of this as it would be a dang simple solution.
One more option, get the ST knuckles machined, just have to tell them what angles to add, they would have to set it up very very well to do it right.
Other that doing something with the rear you are better off running 15x8 and 205 tires even if a 225 fits on an 8 it might not have enough sidewall support though many have done wider tires on narrower wheels with success I prefer the sharper response of a bit of stretch.
Wheels, Rota, I had them in the past and no issues but did not use them for long, I have heard of some breaking and seen some pics.
If you do the low cost 4x100 conversion you open up a big selection of wheels, many roll formed and great prices, there are some 15x8 at 11 lbs for a great deal on goodwinracing
All Ford had to do is mod the fenders just a bit on the ST version, nothing major, and we could of put on 225 on 9's easily but they chose otherwise.
