Thank You for doing the leg work on this. Now that I'm getting close to needing tires, I want to change out the wheels, and have very limited options due to the offsets. I'm guessing that I will not be able to just buy the front dampers for the ST kit. Do you have contact info for someone at Bilstein that you've been working with? It's clear that there is lots of confusion between these two kits, because they are named the exact same with the only exception being the part number. As noted in post #3 this is as high as the regular fiesta kit goes on the ST. When I bought it, it was sold from modbargins as the Fiesta ST kit, and I did not know better at the time (2017). I'm just going to order the wheels I want, with the idea that I will also be buying a new coilover kit. I'd rather do that, then to order wheels that I think will work but not really what I want, then end up not working and I still need to do the suspension.
Both B14 kits are perfectly fine for an ST model as before they had a specific ST kit the original "non-ST" part number covered both for autocross/racing purposes for all Fiesta models. For instance, i am going to be running the non-ST kit on my car and am going with the b-spec spring rates(500/500) from Chris Taylor Racing. The damper/spring combo i am going to be using could be used on both types of the B14 front dampers. The threading of the ST specific damper would hinder its total drop allowed(15mm difference between the dampers) versus the non-ST kit. So if you want the "lowz" status you would really want the non-ST B14 kit as the front can technically go lower than the ST specific kit.
I dont want the "lowz" or "sTaNcE" though as the car is purely a track car at this point. So i will keep it at a reasonable height to keep bump steer in check while allowing me to run significantly higher spring rates than the 280/230 rates that come with the B14 kits.
What size wheel/tire setup? What do you plan to do with the car?
