I know there are a bunch of threads on this, but I am genuinely perplexed on what my issue is. Yesterday I lost boost pressure suddenly while out on a drive. No CEL.
Normally this is due to my charge pipes popping off, but upon inspection they are all on tight. I'm using Whoosh's silicone pipes and they have held since installing them a few years ago, even after several track days.
Next up was to check the wastegate, my dad says the actuator arm isn't moving when revving. We replaced the solenoid, however we get the same result. I checked the AP and I'm honestly not 100% sure what these gauges are telling me, but I turned on the status and WGDC Actual, I do see movement on the WGDC gauge:
The only thing I haven't been able to check so far is the bov due to time, but if the wastegate arm isn't moving at all, could that even be the cause? I'm not sure what else I'm missing, I would think a sensor would cause a CEL. There was no pop or noise before it lost boost. I had it at one moment, went to pass a car and had no power. I'm on a Stratified tune with no eco slot so I didn't switch slots, and also running a Whoosh intercooler. I have a quick video if it helps.
https://youtube.com/shorts/JGk4OzQtPO0
I would greatly appreciate any help!
