I was honestly about to get some draggy numbers, but then I hit a semi tire that got chucked and it ripped off my oil pan and cracked the block. I just got a junkyard longblock picked up. It'll probably be a month before that gets swapped in. I also have a spare trans that I'm installing a LSD in, so It will be quite the change. If I had to guess I was probably in the 110-113 mph 1/4 trap speed area. VD had me around 285hp, and I was running out of fuel on the top with an e30 blend.
Was going to get draggy numbers just to have that as a good reference. I have a tune revision sitting in my AP waiting to be blown in. I'm assuming it is probably atleast a couple more psi. Ended up with the jag injectors, and the nostrum hpfp.
