I used some of the suggestions on this thread. My entire procedure:
- Put car on ramps
- Allow it to sit for about 1/2 hour to cool down.
- Open degas bottle cap. I bought some silicone grease from HD an put some on the 2 gaskets so it doesn't stick.
- Open the bleeder cap. This was a mistake and should have been done later - after the coolant has been drained from the lower hose. I sprayed coolant all over the intake manifold and got it all over the ground because the pan I placed underneath the car wasn't in the correct position to catch it all.
- After coolant stopped coming out the bleeder, place a 10" length of clear tubing on to the bleeder and other end into empty water bottle. The tube and bottle are kept lower than the bleeder.
- Used a pair of pliers to lock the constant tension clamp open on the lower radiator hose.
- Pull the hose off and let drain until it becomes a slow drip, maybe 1/2 hr.
- Put the hose back on and place the clamp back in the previous spot. This would be a lot easier if I'd marked the clamp and hose with some chalk. Next time, I'll do that or take a picture.
- Slowly start filling the degas bottle with coolant mixture. I picked up the discontinued carquest dexcool wannabe on clearance from Advanced Auto for about $4 and a gallon of distilled from Wallymart for my 50/50. You can go over the max fill line by a significant amount, since it'll slowly fill the entire system.
- Keep filling slightly pass the max fill until air and coolant starts coming out the bleeder. It took a very long time before any coolant comes out the bleeder. Maybe 1/2 hour. Once air stops coming out of bleeder, cap it off.
- Now to purge any remaining air. Fill to max fill and cap degas.
- Start car and wait for idle to stabilize. Rev to 3500 and keep there for 30 seconds. Shut off car for at least 1 min.
- Check degas level and add coolant until it reaches max fill.
- Start car and rev to 3500 for 30 secs. Let idle for 30 secs then shut off for at least 1 min.
- Repeat 13 and 14 until coolant level stabilizes and you no longer need to fill. I had to do it 2x total.
I drove for about 1.5 hours afterward and the coolant gauge stayed in the normal zone. I turned the heater on max while driving, was getting a stong blast of heat from the vents, and I was satisfied that I got most of the air out. In all, I think I got just over 1 gallon out. If I remember correctly, I think it was 6qt capacity. If that's the case, I got about 2/3 of the old stuff out. If you're anal about getting all of it, you may have to do 2 drain/fills.
DEss
