hey, few things I want to add:
Roll centre adjustment is RLY complicated. It will influence a lot of things, including dynamic change of toe, camber and your % of ackermann steering. Understanding what it rly is and measuring it can take time. Simply putting stiffer springs or spacers to your front suspension will not rly work wonders, it can even make some things worse. The roll center advice and adjusters you can buy on some "tuning" websites are 75% garbage. This is a good blog read if you are not scared of formulas: Rodrigo Santos - a discussion on steady state lateral weight transfer and how to use it in setup
If you rly want to do this yourself, you need to do the following steps, some of them are complicated and youll need to do research and testing:
1.) Measure your suspension and calculate roll centre for rear AND front suspension.
2.) Measure and calculate CG of your car
3.) Calculate or simulate static load transfer of your car
4.) test and measure your car on the track (this can be complex and Sensors can be expensive to borrow)
5.) do adjustments, go back to step 3
this can be a time consuming and expensive process, also you need to get the tools and learn the math/physics behind it. Load transfer is NOT easily understood by roll centre height. Body roll is NOT easily related to load transfer. Handling is a lot more than those two topics. Increasig roll inertia or roll stiffness on one end of the car changes load transfer to/on the other side, so you rly need to have a good understanding what you are changing.
My advice: try stiffer (not shorter) springs front and rear with your b8, see if the reduced body roll feels better. If yes, have a good time driving it on the streets ✌️
Reigers are expensive and for rally, they are durable and have great valving and damping, but for everyday street use in a non seam welded car with no cage it is maybe not the right thing. If you want to get into some rough road/gravel driving you also need to adapt and reinforce your suspension pick up points with at least a cage. If not you will fuck up stuff in the long run.
