That's part of the reason, as well as to make the side walls less susceptible to cuts when on rough gravel rally stages with sharp rocks/shale, as well as to save the outer tread blocks when on pavement (even if that sacrifices some of the center tread, since the outers are what bites into the gravel most on turns).
It also totally eliminates the risk of pinch flats on said bombed-out rally stages, which can happen at lower, seemingly more 'tractive' tire pressures.
The reason the actual rally
competitors can run much lower pressures is due to gravel rally tires' crazy stiff, and multi-layered/reinforced side walls.
That being said, YES, I am running
way too high a pressure in them, and will likely try lower when these are put back on the car for rally working.
