Looking at adding a cold air intake to my 2017 fist. From what I’ve read if I want to add a full system including the crossover pipe I need to buy a kit with the different evap harness. So I guess the main question is, is it worth it? Should I buy the whole kit with the different harness? Or should I just buy the end section with the filter that doesn’t require changing the harness? Will I still get good turbo sound if I don’t change the entire intake system? How involved is changing the harness and If I buy the correct kit and change the harness will that keep the check engine light from coming on?
let me know what you guys did
