https://www.wilwood.com/Search/PartNoSearch?q=120-12003-BK
This is the caliper I used in my brake package. Brakes feel just like stock from a normal driving standpoint, no extra travel or any weirdness. Using the BP20 pad and it dusts less than my stock summer pads on the rear. Its kinda funny how much less they dust.
Ya that actually is got more piston surface area than our stock calipers. Though you probably balanced it out a bit by going larger in the rear.
I found out are stock calipers have a piston surface area of 54mm which comes out to just 2.12 inches
You can get Willwood 4 piston Superlites in a 2 inch surface are setup i.e. each piston has a one inch surface area or slightly over in 2.46 each piston having a 1.25 piston surface area.
Both sets of Calipers fit anything up to 14 in rotors . For roughly $750 a set from Wilwood , for the calipers.
Now if someone decided to retail to us we might get a better deal . Though that’s really not bad for 4 piston 3.2 pound radial mount Caliper for our cars. That would brake great and have close to if not stock feel backed up by a reputable company.
edit… after being called on this I talked to a friend who actually measured the pistons on the Whoosh Calipers which have the same surface area as stock . Doing the math after that I realized I did make an error above. I also since then found a Wilwood 4 pot dynapro that has a 3.46 surface area and comes in at a very reasonable price.
