Hey everyone. I'm looking to get a set of winter wheels before my ST arrives and I've found the only 4x108 set on the local classifieds. Unfortunately, they're 16x7 +32ET and I haven't seen this size/offset on any other forum. Will these fit at all?
Might be close to the fender, but rolling them isn't that bad if that's the look you want. I'd be more concerned about the tiny 35 profile needed to run 18's than anything. Just my opinion though, as my favourite setup are [MENTION=9]rodmoe[/MENTION]'s 15's for track.
Hey guys, I couldn't bring myself to read the whole thread, so I'll just ask. I want to get ST wheel center caps for the OEM wheels, and I can't find the specified 63.4mm center cap. I know some of you have some, so can I ask you what size you used?
Contact patch straight line won't change, however should I go with the narrower stickier tire or the Yoko's with the additional width... Not sure which is better for an occasional track day daily driver....
With 225/40/R17 you'll be close to the fender as I was before at ET38 on 215/40/R17 17x8 wheels. I was fine at stock height, but every tire company may run slightly different and I using Yokohama S-Drive.
