Thank you, it does not look like there are any in line flow restrictors (the Focus ST does have some), unless they are built into the end fittings.
What do you think?
Seeing that you are the only person i know of that has taken the gear box out. Do you think my issue with the clutch pedal being slow to return is due to something wrong with the Slave or clutch line? (the master has already been replaced by ford.
Ford has no idea what the issue is and i have no were to go at this point.
Clutch pedal comes up fine if using it slowly, if i step on it fast and release fast it comes up very slow.
thank you for any help you can give me.
