Turns out, the LED is perfectly fine. It had simply popped-out of the socket.
Also interesting, I had chosen pretty much the same thing some years prior. What was the "Light Moses" then, is the knock-off version now. The current "Light Moses" listed has upgraded specs.
I bought Katana H7 LEDs in March 2019, 12000 LM 72W 6500K, and they were great except I would have preferred a 6000K because that would better match the color of the OEM LED DRLs. However, one of the Katanas just lost one of the chips, so I bought a pair of Touring Items TypeS H7s at a local Auto Zone to get a quick fix. This replacement is noticeably dimmer, and I’m wondering if I should get another pair of Katanas, or look for something newer and better.
My other dilemma is to find a 6000-6500K LED that will work well in the reflector high beam which requires an H1. I’ve never had much luck getting an LED to work with reflectors.
I did buy a set of that same brand H11s from Auto Zone for the fogs- they are projectors and I’m happy with the results.
Katana with the bad chip:
