Transmission Fluid Poll - Which is best for daily driving in mild climates (e.g. Western OR)?
Transmission Fluid Poll - Which is best for daily driving in mild climates?
  • Motul DCTF
    Votes: 13 16.3%
  • Motul Gear 300 75W-90
    Votes: 12 15.0%
  • Ravenol MTF-2 SAE 75W-80
    Votes: 30 37.5%
  • Motorcraft XT-11-QDC
    Votes: 9 11.3%
  • Other
    Votes: 16 20.0%
  • Total voters
    80
@Salty_FiST
Active Duty U.S. Air Force
Crestview Florida
#61
Keen to find out if the guys that filled 2l if they have any feedback,issues or concerns
Sent from my SM-G991B using Tapatalk
2l of BG Syncro Shift and no problems yet. Shifts are smooth. Got a mountune quick shift, cobb bushings, and a Raceseng weighted shift knob. Shifts so good!
Sent from my SM-S908U using Tapatalk
Santa Rosa
#62
I got my Trans replaced @ 27k....new Ford fluid etc.....Drained that shit out...put in Ravenol mtf-2 75-80....best thing I did so far for the Trans....shift feel was greatly improved!
Super old thread, but I want to give that Ravenol a try to see if it might mitigate my shifter popping out on me in 2nd gear when taking high G left-hand turns... typically after i've gotten the car really warm...
I've already adjusted shift cables, checked motor mounts, and removed the whoosh short shifter.... I'm guessing its Synchros... but I wanna try fluid and then make my conclusion afterwards.
XR650R
Eerie
#63
Can't hurt.
Mpumalanga
#64
Hi guys. Had my axel seals replaced and Ford put in Ford 75w FE transmission oil. Any options on this oil. Had Ravenol before this.
Which Ravenol? There are 3 that you could use. Or BG synchro shift 2. basically the same as Ravenol MTF-2 75W80
