Woods247 BrokeFiST Build
Woods247
Woods247
Atl
Thread Starter #1,201
Yo Matt...haven't kept up on your build but I read this today........did the X47 blow up or are you just looking for a bit more oomph?
It’s still fine. I’m just considering more power and Pumaspeed advised against running more fuel with the X47.
Woods247
Woods247
Atl
Thread Starter #1,202
Spent the afternoon playing with fitment of my new 235/40/17 RT660s. They’re significantly wider than the 235/40/16 RT615K+. I had to roll and pull the rear fenders a bit and have custom 7mm spacers made for the front so the inside of the tire cleared the suspension. I’m using the 17x8 et35 Rota Grids with this tire. Seems like they’ll work but I’ll find out for sure at the track next weekend.
45C5CC00-080E-4B41-84F8-266E22D731FD.jpeg 3D9B3309-45E2-4EF0-8DEF-8E00969DB281.jpeg E3A4060B-21C8-45D1-9151-E62250DEF05E.jpeg AD746F17-B134-40C8-BCB2-6FE4E2F9146C.jpeg
Woods247
Woods247
Atl
Thread Starter #1,204
Damn, seems like a lot of work, I hope its worth it
It’s been a lot of work. I could do it all again in 1/4 of the time now that I know exactly what has to be done. The extra grip was worth the effort for me.
Fusion Works
Huntsville, AL, USA
With these tires it’s almost exactly 7”. Pretty tall.
Interesting. Looking at my wheel setup, (granted puny 205/40-17s) it looks like I could easily fit a 235 under the fenders if the damn tire companies would make a short 17in tire. Wish I knew some people at tire companies.
I measured mine when I did the setup yesterday and am at 6in. Today I smacked a pretty big pothole and didn't bottom. Also looking at my shock travel indicators, I may have just kissed the bump stops, which leaves me with 1.5in till everything goes to shit. HAHA
How much negative camber do you have? -3 up front and -2.5 rear?
Woods247
Woods247
Atl
Thread Starter #1,212
Diameter of the tire has definitely been the challenge. I cut out everything under the front fenders and built brackets to hold the fender and bumper cover out in order to clear max compression. I always bottom out at local tracks so removing that stuff was critical. There’s a lot more work involved to make them fit but yeah, taller tires (most are 24.4) require A LOT of work even with flares.
Woods247
Woods247
Atl
Thread Starter #1,213
Woods247
Woods247
Atl
Thread Starter #1,219
Looks beautiful! I'm curious how much I'll have to bend/cut to make 225/45-16 r888r fit.
If it’s taller than stock (or 24” + in diameter), you’ll probably need to remove the boxed area that houses the three pain in the ass bumper/fender bolts. I was hesitant to cut all that out but man it’s sooooo much easier to take off the front bumper cover now. Rivnuts are the best!
