That's good to hear! My plan is to swap between the DTC30 and some more street happy pads, I only do track days 1-2x per year so its not the end of the world swapping things around. The last couple years running normal DOT 4 fluid I was bleeding brakes before and after each event as the pads would melt and get funny feeling as well as boiling the fluid.
I might just end up running the DTC30 pads all summer and just flip to a cooler temp pad in the winter. I suspect the DTC 30 pads are a bit sketchy when its actually cold outside as they wont warm up very quickly here in MN in the winter.
On the squeakiness note, after you melt EBC Bluestuff pads they get a bit squeaky too. lol. they work all year long for me though. All things considered its a decent pad as long as your track sessions are short enough to give them time to cool down. they also don't require any time to come up to operating temp on track/autoX, but 15 min sessions on a short track doesn't work for them, they never have a long straightaway to actually dump off heat.
yeah good idea swapping pads for the winter if you're in MN. It works well all year around in CA, but it seldom gets under 50f here in Los Angeles and much of Northern CA that I visit.
I have a hunch the Hawk HP Plus, thinking step below Hawk DTC 30s, rated more of an AutoX pad might also work good. Had them on my stock powered and at times heat soaked evo x with endless fluid and never did pads melt or brakes overheat.
