Partiers,
I bought an ummarried used AP from another member on the forum and it had adapt-x and cobb stage 1,2,3 tunes. The adapt-x tunes are VIN locked to the previous owner but the AP let me flash my ECU with the program so I decided to give it a try. Did 5 and 6th gear pulls per the instructions pwnall gave to members here but the estimated HP numbers never went about 155hp and the torque stayed around 170ft-lb. I figured the adapt-X IS actually VIN locked and if you load it you're basically putting the car into a nanny state with no real boost (even though my AP said i was getting between 22-23lbs of boost at peak).
So this morning I switched to the Cobb Stage 3 tune and estimated HP went up to 162ish but torque stayed at about 175ft-lbs and boost got up to 22 or 23. I know these numbers are estimates but they are putrid and I'm not really noticing ANY changes on the butt dyno either.
I have one step colder plugs gapped for tune+ (bought from tune+ and I've been told they're about 0.025-0.026) and a ramair drop in filter and that's it. If anyone can give some insight I'd appreciate it. I know Cobb 3 calls for an intercooler, downpipe and catback exhaust but everything I've read has stated they're unnecessary other the FMIC so you can avoid heat soak. I only like doing a couple pulls in a day so figured at the least the first pull would get me 200-210 estimated hp and more importantly 260-300 estimated torque.
I can post datalogs when I get home tonight so also just giving me advice on what to monitor would be great. Right now it's:
ignition correction cyl 1-4, ignition timing 1-4, hp, torque, rpm, transmission gear, oil temp, charge temp, boost
