Got my MTC "Cobb knockoff" intercooler installed. Quite a challenge getting everything to fit as the intercooler is pretty large and fills up every possible fractional inch of space. Some cutting had to be done to get the lower splash shield back on, but nothing major. Managed to do it surgically and cleanly enough that it doesn't look too bad. I'll probably seal the exposed areas up with flashing tape or something to keep excess water out of there during rainy weather driving.
Other than that the car looks incredibly stock. I left the front "braces" in on the lower air dam to keep it looking that way on purpose and it totally fills up that gap with the core. No end tank visibility at all.
As for performance the car didn't exhibit a rise in charge temps above 9F during third and fourth gear pulls to redline and it even drop charge temps in the mid range before coming back up again. Boost feels like it comes on a bit quicker and stronger than stock, though logic tells me that my butt dyno lies to me on that. It feels better in the upper rev range because of the cooler charge temps, of course. Prior to install I did a few pulls on the highway in 42F weather (it's been beautiful this weekend here in Chicago!) and managed to soak up to 73F, which is a delta of 31 degrees! Needless to say this is a much welcome improvement.
The core passed a boost leak test as well. It holds pressure extremely well using a home made compressor and adapter setup courtesy of a good friend and it doesn't leak boost during driving, either. I'm still hitting my boost targets per the Stratified tune and tapering off accordingly at 24psi. I'm adding more spark during pulls again which indicates the car is ready for a revision and can take more power from my fuel, so that will be coming soon as well.
For the $350 I paid with shipping for this thing it is phenomenal. The welds could be better, but they get the job done. Very satisfied.
I'll post logs and pics when I get to my computer at work.
I highly recommend this core unless you fear trimming or fighting with the lower splash guard like I had to. Very worth the money in my opinion!
