Just so you know, I bought a set of Jag injectors and the Jag HPFP, it looks like it will fit. On the XKR they use two of them, one for each bank. The next windmill.
It just may. From what I understand the Xtreme-Di hpfp flows at 200 bar which is the same as the hpfp from the Jag. I think at one point pumaspeed was selling a bosch uprated hpfp and it looked similar to the unit that came out of the Jag and Land Rover, but I can no longer find it available on their website. There was thread started about it, which didnt gain much traction, because aux fuel.
I just bought the Jag HPFP, on paper it looks like it will fit, need it in hand to be sure. I think I found a place to actually test the Jag pump. XDI makes the uprated pump for $1300, the jag pump from Rockauto is $153
This search was short, Bosch® 66807 - Direct Injection High Pressure Fuel Pump (carid.com) Read down to the description, this is a 200 bar pump, cost $160. On Rockauto RockAuto $153 for same pump, Xtreme DI Ford Fiesta ST 1.6L - Xtreme-Di $1300.99 this is a different design, 200 bar, Puma speed used to sell it for $1300, no longer selling it. I have ordered the 66807, once I get it I will see if it fits on the ST. If I am reading the injector test sheet right, the Jag injectors max out at 150 bar.
