You could make your life MUCH easier by purchasing one or two of these. I fill each with 6gal e30 mix and keep them at home. 6gal is 1/2tank so when I get below 1/2 on the gauge, I just dump a can in and the car is full again. VP nozzles insert without any issues and the fuel dispenses quickly.
Edit: I can’t hotlink from my phone for some reason. Try this: VP Racing Fuels 3512 + 3044B 5 Gallon Square Red Racing Utility Jug w/ 14 Inch Deluxe Filler Hose https://www.amazon.com/dp/B00AVQC01U/ref=cm_sw_r_cp_api_glt_i_A75NRV567K68GM968EG4?psc=1
Quick 2 questions though which may sound dumb -
- When you say you fill 6 gallons of E30 mix, is that 5gal 93oct + 1gal E85?
- I have these jugs and see they only go to 5 gallons. Do you just overfill a bit to make 6 gallons? It looks like 6 gallons would fit, so I'm assuming so.
