If you miss the TQ shove it comes back with an E30 Tune on stock fuel system. I pulled 284ft lbs of TQ and 284 HP on Vydno. I saw 298ft lbs of TQ and 298HP on my AP on the E30 and after pulls datalogged saw 290-300 whp and 340ft lbs TQ on Vydno.
The s280 does not really spool at that much slower than the stock Turbo and in fact in the lower rpm band to about 3k really almost matches the stock TQ wise . If I recall after reading other dyno logs it was done 50FT lbs at like 2500 rpm compared to the stock turbo . Though once it climbed over 2500 rpm it matched the stock turbo till around 3000 rpm and then it starts to go and the crazy part is it just goes to redline . It just has pull all the way up.
In fact if you look at my vydno charts I posted you will see that broad arc up and across that the turbo is known for .
Anyways ya an E30 tune will give you back the donkey kick you miss if you really want it. Though I get it if E30 is a hassle to do and you area is getting 93 then go that way and you will get more of the donkey on 93 as well IMO.
