Question: What 200TW Track Day Tire Should I get for a 17 inch Wheel?
Woods247
#81
Do the RT615k+ need to be heat cycled also?
Not really. That’s one of the reasons I love them. I usually drive them on the street (or a 7/10ths first session) to scrub them in then they’re good to go.
E
Thread Starter #82
Update: I finally got around to doing another track weekend with the FiST on these tires. I did two days where the first one amounted to unlearning all the bad habits I picked up a month earlier while driving a different car with double the HP. The second day I was finally getting things sorted out and was getting my fastest lap times and doing it consistently.
The bad...it was a hot day and the car suffered. Temps toppped out at 102 in the afternoon and the car was down on power. No overheating even with the stock radiator but it was just a dog when on the straights and getting into elevation.
Worse...my 1.9 degrees of camber front and whatever stock is in the rear was definitely not enough. The outsides of the drivers side tires are pretty trashed and I've got maybe one more day left in the tires. But that was expected so no worries. It was a trade off because I didn't want a more aggressive just for a couple track days over the summer, especially when I'll probably going back to the stock suspension in a few months.
Overall the tires worked great for dipping my toes into the 200TW category. I don't have anythign to compare them to but I will say I liked how they were consistent throughout my sessions. After a lap and a half to get up to temp they stayed predictable even after as many as 14 laps in a session in 100 degree heat.
Here's the obligatory fastest lap video. Over 2 seconds faster just with the tires and that's compared to a 55 degree day when the car had a lot more power. I'm still learning the track so there's plenty of room for improvement...
View: https://youtu.be/kMOtLn3hbBQ
#83
Man ORP is such a fun track.... Its good to hear that even in that heat you didnt overheat the car. Struggling with overheating at AX, I have shy'ed away from track day in the FiST for fear it would be pointless.
#84
Off come the Firestones indy 500s....on go the RT615K+'S.
CSM
#85
I think the new continental tires that were co-developed with hoosier are the go to endurance / track day lapping tire. Worth checking out as a replacement for your RT615k+
ronmcdon
#86
thanks for mentioning that as I had no idea there was that option.
sadly cant get them in 16s but there seems to be good 15 and 17in sizes.
CSM
#87
i believe 16s are coming at some point... but initial reviews are very good
#88
What are they referring to them as?
#89
Extreme Contact Force.
I believe that Hoosier might be producing these for Conti, under contract? [dunno]
CSM
#93
Also there's a rumor that there are a few prototype sets floating around with national autocross folks for testing purposes. Different compounds for autocross use
Magnetic
#96
What device were you using that gives you the g-froces? I've been looking for 1 so I could test suspension upgrades.
CSM
#99
Following up on this.
I was at SCCA Solo Nationals last week and ran into one of the Continental Tire Engineers. There is indeed a 200TW version of the Extreme Contact Force intended for autocross coming out, probably 2023. It is currently in development. They are doing the best to make it the be all end all 200TW tire for autocross use.
Woods247
I’m pretty pumped to try the 225 Force next season. If it’s as consistent and durable as the RT615K+ (but faster) it’ll be worth the extra cash.
