Turbo Technics S280
it was not an incorrect claim I can call it whatever I fricken want. You just get all wound up about it and face it you do or you would not be responding everytime. Like I said before give it a rest I will just keep winding you up and punting it. [emoji38]
I think its the other way around there Brodiglio!
Fayetteville, NC, USA
Not that I personally give a rat's ass, but I think that it would be helpful for people new to the platform to know that the S280 is a hybrid based around K04 components and bespoke housings, and is not based on the stock KP39.
The KP39 punched out with bigger wheels, which is usually referred to as a hybrid here, is not quite the same animal.
AzNightmare
Iqaluit
Unless there is a definitive reason between defining a hybrid vs a big turbo (or simply non-hybrid turbo), such as construction is different, method to make power is different, different technology, etc.
We're just using terminologies based on preference.
I'm not sure what criteria Turbo Technics used to label the S280 as a hybrid turbocharger. How does it differ from a non-hybrid turbocharger?
If it merely comes down to preference, then in the context of this FiST platform at the very least, it's been universally understood that a hybrid is just a stock kp39 modified like it's on steroids.
Anything else that doesn't rely on the stock kp39 is a new (big) turbo.
For people that are either new to this platform or new to turbo upgrading, understanding there is a distinct difference in characteristics between a hybrid and a big turbo is valuable. And it helps to preserve the simplicity of:
hybrid = stock turbo, quick spooling , less top end power, lower power ceiling, runs hotter, absolute direct bolt on, etc.
big turbo = completely new turbo, slower spooling, more top end power, higher power ceiling, runs cooler, might require slight or a lot of modification, etc.
Maybe there is some overlap, cause the S280 is small and shares some "hybrid" characteristics. That was the selling point for me, but I also understand it's technically a different turbo altogether, which is also the selling point for me. In this context, I wouldn't want people to get mixed up calling the S280 a hybrid like it's a X47. Because the characteristics are different.
MagnetiseST
Dania Beach
Its based on a K04 frame like @oldedub says, therefore I believe it IS a "hybrid turbo". However it is NOT a "hybrid FiST turbo". It has bespoke compressor and exhaust housings designed specifically for this application, it requires a special hot-side pipe since the compressor housing / outlet is substantially different than the factory one. It does not use the OEM style inlet elbow or three bolt pattern, the only "OEM" part it retains is the exhaust housing design (since its not an OE exhaust housing modified for use with this turbo). That being said, it is closer to a "big turbo" than it is a hybrid like Whoosh, Pumaspeed, or a C39.
WA, USA
Well we have a 2J side exit on the car. It was conveniently sitting where an extendable magnet could pull it out, but I only found that out after I dropped the middle section lol.
Is this from the turbo failure reported about last week? Or is this a new “issue”. Either way, good god…
