I've been battling loss of coolant and coolant boiling over with my '14 ST - first it was a cracked coolant reservoir tank which I replaced with a cheapo aftermarket one. Now the cheapo replacement won't hold pressure either (I think the fill neck is slightly out of round and the bottom o-ring on the rad cap can't seal properly (I replaced the rad cap - same problem). The system will only hold 10 to 12psi before it starts leaking out of the overflow.
So my dealer wasn't able to do the coolant recall last time I tried and I'm reluctant to take the car in again - I autocross the car and don't want to have it re-flashed and end up with the lower rev limit that comes with the reflash.
I believe the recall comes with a new coolant reservoir tank (can anyone verify?) so that would be a bonus if I can swap out the POS aftermarket one.
Here's my question - is there any trick to getting Ford to send me the parts so that I can do the recall myself?
