You need to keep the bias in check. As you get faster and brake later, the rear brakes are critical in keeping the car pointed straight. If the car exhibits excessive “tank slapping” under heavy braking, try running a more aggressive rear pad. You should also consider the rear pads if you upgrade your front calipers. Goldcoast Automotive has a fantastic inexpensive option for us as does Whooshmotorsports
Also keep an eye on rear tire pressure and temps across the tread. Rear grip is also critical for stability under heavy braking from high speeds. I added a little rear camber as well (-2.1 degrees) using washers on my lower hub bolts. Ghetto I know, but it’s cheap and I’ve been running it like that for a few years without a problem.
I boiled the Motul fluid more than once when my car had stock brakes, so I switched to Type 200. The next step is Castrol SRF, but I never needed it in this car.
I trail brake a lot as well. I replace rear pads just as frequently as I replace the front. If you leave the car in Sport mode, the rear brakes are activated often so keep that in mind. There is nothing wrong with using Sport mode while you’re learning the cars limits. It’s safer for everyone on the track.
