2860 install
#81
I'm not finding that....
There is no adapter * I told those Fu$kers @ ATP . I ended up getting an spectre METAL intake adapter and used that as joiner between the Elbow and another silicone 180° straight piece to make the elbow longer. Worked put perfectly*
SpiceyorangeST
Thread Starter #82
I will have to figure out the diameter
#85
The local Autoparts stores usually Carry a brand called Spectre....literally the same thing just can usually be had sooner than later.
SpiceyorangeST
Thread Starter #86
I'm literally just about ready to fire this thing up, just need to get the intake on.
SpiceyorangeST
Thread Starter #89
I actually need to do that then pull then fuel fuse and run it out of gas because I then am doing those injectors and hpfp
TDavis
#92
Odd. My ITG cross over reached it no prob
SpiceyorangeST
Thread Starter #96
So I've done some looking in the manual and it says r47 is the fuel pump relay. I can't really tell which fuse that is on the under side of the lid since the shapes don't really match up. Which one is it? 20210713_111904.jpg
#97
If you are preparing to prime the turbo...
I held the accelerator pedal to the floor and pressed the start button. Press it again to stop cranking. It will not start. Keep the pedal mashed the whole time. Repeat as desired.
Dunno why everyone is making this a headache. I had zero trouble putting mine in.
Mine was easy, just needed the extension to make my crossover meet the turbo inlet. I also didn't mess with aux fuel or anything else.
