Yep - already installed the kit. I had the EBC Apollo kit in hand, but I couldn't find a wheel that would fit the kit without a +10mm spacer. So I exchanged the EBC for Wilwood, knowing it's not going to be optimal for the track. I'm hoping the Spec37 rotors and upgraded (BT-20) pads make the kit work a little better than the OTS kit. What problems have you encountered with the Wilwoods?
@ronmcdon - that's a very similar set-up to what I was running (Orangestuff, Stoptech Slotted, and RBF600) - I really like the feel of Orangestuff, but I was melting my pads, and scorching my rotors (almost) every track day. However, and i should have mentioned this earlier, I was only bleeding the fluid a couple times a season. This could have been primary culprit ...
@Lays You gotta take the plunge and participate in a track day. Your set-up would be great out there and would surprise a lot of people. Just don't go on the same day I do - You car would make mine look real slow
Kidding - I recommend trying out the BMW Club HPDE. It's pretty chill and they have a lot of great cars that show up.
