My headlights arrived! Before I open them I want to get all new bulbs. I found it once in this thread and I can’t find it again. What are the best bulbs to get for these headlights? I want to get all the bulbs: headlights, turn signals etc
Thanks
If the headlight is Euro version then i am pretty sure the low beams use H7 bulbs, the turn signal uses 1156 or BAU15S, the high beam uses H1. There is no parking bulbs because the DRL will serve that function.
For the low beams, if you are going for LEDs, make sure that you have a rubber cap to accommodate the fan from the bulb or if you want you need to cut a hole on your current dust cover.
For the turn signals, make sure you get a high wattage bulb or be sure that they are canbus type or else you will need resistors to prevent it from hyperlflashing.
For the high beams, you need really special type of H1 LED or else it will either not fit or be a nightmare to fit and you will have to force things and might break the holders or other parts in the housing.
Good luck!!
