- Member ID
- #11769
- Messages
- 90
- Likes
- 113
I have a quick "what size should I get" question that I'm sure a tire & wheel guru can easily answer.
I'm finally graduating to a ~200 TW tire for track days. I'm looking at either going for the stock size of 205/40R17 or if I can bump that up to 215/40R17 or more (doubtful!). I'm sure sizing up is dependent on tire brand/model. Here's my setup:
Wheels: 17'' Sparco Trofeo, so I think that is the stock size 17x7 with 47mm offset.
Suspension: Bilstein coilovers with front dropped about .75'' and rear .5''. Front camber is maxed out with camber bolts at about 1.9*.
Uses/Goals: Tires will go on my track day only wheels and I'm balancing getting as much grip as possible but I also drive 100 miles each way to the track (more when going to new tracks) so I'd like to get a few miles out of them.
Budget: Yeah, I'm on one. The cheaper the better but I'll spend what I have to to get the right tire.
I don't have many tire shops in my area so I'll probably purchase through Discount Tire and that pretty much gives me four options for sizing up:
YOKOHAMA ADVAN A052
Falken AZENIS RT660
Falken AZENIS RT615+
YOKOHAMA ADVAN NEOVA AD08 R
Does anyone have thoughts about these options options? Any other sizes or strong recommendations to consider, even if it is in the stock size?
FWIW, I did a track day last weekend and asked as many people I could about their tire preferences. R888R's came up a lot and it sound slike they wear slowly so maybe I should get those and stick with the stock size...
YOKOHAMA ADVAN A052
Falken AZENIS RT660
