I believe if you’re going to be pushing and tuning this car hard, these mods are necessary to maximize your fun, and the motors safety by keeping it cool!
1. Radiator upgrade of some sort, I recommend mishimoto personally, best flowing core and largest coolant capacity. I have experienced the horrors of having the stock radiator, it isn’t fun. And if you want to run an e30 tune and your a/c at idle with stock radiator, you will overheat (at least I did once before I learned my lesson with that and people I have spoken to have).
2. Intercooler of some sort, I recommend Depo or whoosh, both are a great value and get the job done for stock turbo and hybrid turbo applications! Big turbo I cannot attest to as I have never had one. But I feel the stock intercooler is pretty much maxed from factory.
3. A tune by Adam at Tune +, simply the best in the game.
Something I want to try next is an oil cooler, I think the car could benefit from that as well, mishimoto is the one I’d try, since I know it fits with the radiator.
Let me know what you think!
My full mod list:
Cobb accessport v3
Cobb accessport mo money face
Cobb accessport a-pillar mount
Tune+ e30 tune
Cobb rear motor mount
MBRP 3” catback exhaust
Mishimoto air intake system
Whoosh motorsports 3” catless downpipe
Depo racing intercooler
Velossa tech ram air big mouth
Go fast bits dv+
Whoosh motorsports hot side charge pipe
Whoosh motorsports cold side charge pipe
Whoosh motorsports turbo inlet pipe
Silver Tial MVS 38mm external wastegate
Dual spring setup, large black and small red, 1 bar or 14.50psi total
Stock turbo setup for external wastegate
Stock exhaust manifold ported w/ v-band flange welded on top for external wastegate
ZZPerformance Dump Tube on wastegate
Whoosh motorsports shifter base bushings
Perrin 2” shortie antenna
Billetworkz weighted shift knob
H&R super sport lowering springs
Mishimoto fiesta ST Radiator
Mishimoto fiesta st radiator fan shroud
RokBlokz black rally mud-flaps
Vegamotorworks v2 wing extension
Whoosh motorsports magnetic oil drain plug
Project Kics magnetic transmission drain plug
My full mod list:
Cobb accessport v3
Tune+ e30 tune
Go fast bits dv+
