Hi,
Looking for some advice if anyone can help?
I was having some serious idle issues in the past.
The car was eventually diagnosed with a bad actuator and wastegate solenoid.
I got an OE solenoid and a forge motorsport actuator with an updated spring.
The car is finally now idling ok after a lot of troubleshooting.
The car is tuned to roughly a stage 1.5 for all the world, I am an exhaust system short for full stage 2.
The issue is, and I will attach screenshots, boost itself builds perfectly fine. The torque stutters as it builds. It will be more clear in the graphs. But is very very noticeable in the driver's seat.
I have gotten the actuator tightened twice since installed for fear the wastegate was flapping. But I'm limited in where I live in ireland for getting this to pros to properly review.
But for the now, I'd just love for this to be resolved.
Here is a list of what the car has
k&n filter
mountune silicone boost pipes
mountune lower intercooler hard pip upgrade
mountune high flow induction hose
mountune coolant pipes
mountune intercooler
mountune mp215
vudu sound symposer delete
eibach pro springs 30mm drop
mountune short shifter
cobb rear engine mount
Forge Motorsports actuator
upgraded exhaust mounts
jtk custom remap for the hardware upgrades
Vudu magnetic sump nut
ngk spark plugs
gfb dv+ diverter valve
new wastegate solenoid
new top engine mount
new map sensor
new boost sensor
new purge valve breather system
new clutch
new seals and bearings in gearbox
k&n filter
mountune mp215
ngk spark plugs
new map sensor
new boost sensor
new clutch
