After getting it back from the LSD install I noticed less boost. After 5 days I finally heard a loud hiss when floored. I pull over to look and the hose going into the throttle body was loose and slipped down 1/2" or so.
I decided to take pics and tighten it myself, but the evap hose was slightly in the way. I disconnected it and took my pics. I realized I needed a socket to reach the small space and nut on the clamp. I decided to drive home the 1.5 miles. Yes....yes, I forgot to connect the evap line back up.
I started the car and immediately it went to redline. So fast. I hit the stop button while the clutch was still engaged and in neutral.
I reconnected the hose and the clutch was barely resistant and groaning when coming back up only part way. I was able to put it into gear. I should have driven home, but again, stoopid decision to wait and see if it just needed more vaccum or....? I stopped the car and started it back up. Mistake.
NOW it goes in as if it were being sucked down and doesn't return unless I pull it up. I pumped it by hand and I have fluid on the ground.
EDIT: no effort to push down or pull up. I didn't know pedal has a cammed action to it. It will not sit anywhere except fully up or down.
