I've tried a lot of settings, even maxing the rears, but it still squats under hard acceleration. Normally I run like 8 from stiff up front and 10 from stiff in the rear. I bought a set of 10k springs from them for the drags to help fight it, and it barely squats at all with that setup, but I wouldn't want to drive around like that on the street, the rear would kick out definitely in corners, and hard braking doesn't feel very great lol. Ya have to steer it a little, lol
With stock turbo it was fine, but the car makes like twice that amount of power now, so I think it just overpowers the springrates.
Nothing wrong with the rear kicking in corners the car was actually designed in way that it does that. If you have to steer it a little while braking I would be looking at your brake setup as unless you are running bad tires or shocks, definitely The suspension should not have a dramatic effect on braking especially spring rates. Something else is going on in your setup IMO.
