You will most likely rub on angled driveways and maybe hard cornering unless you add a couple degrees of camber.
I rub on driveways but not hard cornering unless it's a sharp corner.
I'm sitting on 205/50 - 15x8 +35. About 2.5 inches lower than stock, but I also have my dampers set pretty soft because I daily the car so a lot of driving is rough streets.
Sent from my SM-N975U using Tapatalk
