YSR has yet to provide me with replacement shocks - the latest statement from YSR is as follows:
We have test fit the Ford Fiesta St Rally Gravel coilover kit with 4kg springs for an extended period of time, and this 4kg rear setup was quite soft and matched perfectly with our shock valving. We believe this customer has the shock stroke adjustment in the rear set incorrectly, so that’s why he believes the ride quality in the rear is too stiff. We only have a 3kg-180mm spring available, which is 20mm shorter than the existing spring. This would cause the rear of the vehicle to not be able to lift as tall as the front which would create issues for handling / control
So, even after telling them that I'm not even running the YSR shocks and am actually running Koni-Orange shocks and am experiencing an extremely bouncy ride, the conclusion is that I installed the YSR shocks wrong and that's why the ride, currently, with the different branded shock, is poor.
YSR hasn't even asked for the quality control card / packing card from the boxes which shows who signed off / released the products. Pretty hard to take quality control seriously when a customer has an issue and you don't track it down to the source.
YSR has also, CLEARLY, never driven a FiST with 4kg springs and at the same time claim it's 'quite soft'. It's insane.
So, now I'm back to using the MeisterR's while saving up for the
FlatOut Suspension GR40 kit along with contacting Visa for a chargeback due to YSR not providing the product as advertised (changing the website after I pointed it out....) and not replacing the shocks which never worked.
TL: DR:
DO NOT BUY YSR PRODUCTS
