what do you mean by lower profile and how it's triple tube aluminum? what are the advantages of that? lower profile as in better ground clearance and the material used more durable? yeah a shame we don't get summit parts, no doubt. hopefully they'll be easier to obtain after covid.
would be happy to get Summit because I am quite enjoying getting british aftermarket parts for its own sake. not sure if BDM (instead of JDM) is a thing.
yes better ground clearance. Three forged aluminum small tubes alongside each other its a way to get strength with lightness. if you cut one open it would be like there are 3 small chambers. Yes inherently a round tube with be stronger than an Oval tube and and a tube period will be stronger than a piece of flat metal. depending on the composition of said material.
Now the two operative things I am looking for here is weight and strength as strength will help in the rigidity we are looking for here. I will mention Raamaudio here as when he went to Octane Academy back in like 14-15 he had his own homemade traction brace spanning the two front lower control arms. He took his car there and at that time the whole thing was a lot more involved as they actually stuck his car up on the lift at the facility and looked at his mods. The Ford Racing tech their looked at and went yup thats all you need on this car.
Now thing is it does not stop companies from making unneeded parts that might sell because “is stiffer” I know you are well aware of this from the previous world we were/are still in ( somewhat) lol . Lots of unneeded stuff was made for that platform and marketed as must have.
So there is a debate how much extra stiffness does this chassis need? Much like M Sport fan has pointed out no one has put out better track times because they used the Pierce 6 point beyond anecdotal.
So there remains skepticism as to how much is needed.
Though looking at the way the control arms are and looking at companies like BMW who actually made a factory cross brace to put on the convertible M3’s for added rigidity which everyone puts on their coupes and 4/5’s as well.
So the two point is most likely a valid unit with the 4 point just tying it all together a bit better.
Sorry if I digressed in explanation mode. The other factor is ground clearance. Which is why I looked at the both the TB and the Summit and much prefer the Summit design wise.
While the TB is functional it is nothing pretty. I scratch my head as to why the V angles were put in but then I realize using the flat metal like he did he might have had to add them to increase the strength enough again this is where tubes win out.
I should after watching friends Pierce two points collecting rocks on the road and getting bent because of it multiple times. I was interested in as much ground clearance as one could get.
Perhaps doing Poly Control arm bushings might be the better route.
That is the how and the why.
