Ok, so I'm joining the Meaty Tire Club in a few months when I get new summer wheels and tires. Follow my logic and tell me if you think these will fit.
I'm going down to OZ Ultraleggera 15x7 42mm wheels.
According to the
tire size calculator I'm looking at,
The top of the tire
to the fender well is:
6mm Farther
The inner sidewall to the suspension and frame is:
4.5mm Closer
The outer sidewall is:
15.5mm Farther Out
So since the tire is 23.0" tall instead of the 23.5" stock tire, it will be a bit farther from the top of the fender well, which is good because I have Whiteline 1.25" lowering springs, and I'm rubbing a little bit with my winter 23.7" tall tires (195/50/16).
I'm thinking the fitment will be fine, just a tiny bit closer to the suspension (4.5mm) and then stick out a little over half an inch (15.5mm) farther than the stock wheels, which doesn't seem like much. I definitely don't want the Mexican Stance look.
What say ye?
PS: I realize the wheels are a bit on the narrow side for a 225, but the wheel width recommendation is 7.0-8.5", so I should be fine. Should also give it a little extra meatiness to the look with the tires being almost an inch wider on each side than the wheels. Mmmm…extra meaty....
